When are you going to make season 3, and season 1 temple runner? For season 1, you can make the part, where you have to go into the wheel room, and you can click on the 1st button at the left of the wheel, and at the bottom, and the right, and the top, and go into the throne room, you click on the throne, and go into the heart room (make the door at the right availiable, it's the wall climb, what do you expect?!) or into the holes of python, climb up the ladder, or go into the tomb of the ancient kings, click on the coffin, click the part to get the key, and click on the door(s) to the shrine of the silver monkey, or plow through the wall, and go into the well room, rise up into the torch room, you click on the bucket. click on a torch, and click on one of the 3 torch holders, and go into the silver monkey, click on the statue pieces, like in season 2, and place in the statue holder, and go into the treasure room, click on the treasure chest to go into the python room, or click the actuator to go into the observatory, and spin the sundial, and go across the bridge, click on the actoator to go into the 3 gargoyles, race down the stairs, and back through the temple gates. Also make availiable the part, where you can find a 1/2 pendant in the temple, you click on the 1/2 pendant button in the room, and go on with an extra life.
Season 3:
Crypt, like season 2, you click on a skeleton, you go into the pendulem room, click on the rope, and click the column, and show the rooms avaliable. Kings storeroom, like season 2, you click on the pots, and show the buttons for the pedestals, and after activating the right pedestal, show the buttons to go into the ancient warriors, or the chamber of the sacred markers. Go down, and click on the markers, and place them on the wall at the right, with the marker holders, and show the doors open. Go into the ancient warriors, when you enter from the chamber, click on one of the armors, and open one of the doors, if you enter from the chamber, or the storeroom, don't open the other door, keep it locked, so in case if someone goes into the next room, you have to complete that objective, and go back into that room. Then go into th shrine of the silver monkey. Like season 2, click on each part of the statues, and place them on the statue holder, and go into the password room, like season 2, you click on the tablets, and find the right password, and open the slide to the pharohs passge, then go into the quick sand bog, and go up the ladder, or blast through the wall into the dark forest, like season 2, click on a tree, and get the key, and go into the court jesters, and like season 2, you press one of the bottons to the correct paintings, and go into the tomb of the headless kings. Click on the vines, and show the button to the head aftterwards, and click on it, and show the buttons to the heads, and the correct one will go into the pit, then climb through the ledges, and like season 2, you click the temple gates button.
And place the button of the artifact, and put into the room of your choice. Also make availiable the 1/2 pendant challenge.
