Author Topic: Legends of the Hidden Temple: Unearthed  (Read 3211 times)
Offline NekoSuave
  • Orange Iguana
  • Gender: Female
    • View Profile
« on: June 20, 2013, 09:20:31 AM »
For a while now, I've been considering making a fanfic series of my own, with the desire growing after I participated in the "Make Your Own Episode" thread. Finally, I caved and starting searching for eligible artifacts that I could use. Of course, I still wasn't sure if I should go on with this. With some encouragement from my friend, however, I finally decided to go through with it. Welcome, everyone, to Legends of the Hidden Temple: Unearthed.
Before I start, however, I feel that I ought to share the artifacts, the Temple Layouts, and a few notes with you...that, and I'm still in the process of finalizing a lot of things, so I can't start right away.
Above is a guide to the rooms. I decided to go counterclockwise, starting with the upper entrance room and ending with the lower one. You probably noticed that I didn't label the Pharaoh's Secret Passage area. Honestly, I don't really consider this a room, just a different method to get from room to room, but with a name instead of simply being called a slide. Besides, Room 8 has an objective now, so there isn't an actuator by the passage's door, but I'll get to that in a moment.
Season 1
In total, Season 1 uses six layouts.
Layout 1
1. The Crypt: Same as it was in the past two seasons.
2. The Overgrown Pit: Vines have swarmed across the floor and have overtaken a good chunk of the Pit; if one looks closely, you can see the pendulum from Season 3's "The Pit and the Pendulum" ensnared by them. From here, players can choose to go to the Lair of the Butterfly, the Heart Room, or the Eclipsed Light Room.
3. The Eclipsed Light Room: A black orb sits on a gray pedestal near the center of the room, and behind it are three panels. One of them has a light bouncing off of it. Players must adjust the panel so that the light hits the black orb in order to move on. The back wall is colored a dark blue, with many small, white dots on it, as if it's supposed to resemble the night sky.
4. The Heart Room (Unearthed): In the past, all you had to do was hit an actuator to move on. Not quite the case here. The room is almost entirely pitch black, save for a few light sources. In front of the room are two levers. The player must turn them at the same time, for a total of three times, in order to light the room back up. Right before the light returns, the center of the wall will glow a faint red, and a heartbeat noise will start to play. Due to safety concerns, Temple Guards won't appear until after the objective is completed, when the lights return (imagine a kid afraid of the dark encountering a Temple Guard while there wasn't any light...not a smart idea). Aside from the changes made above, the room retains its original design.
5. The Room of the Ancient Warriors: Same as Season 3.
6. Shrine of the Decayed Monkey: This room has seen better days. The monkey statue is a shadow of its former self, and it looks like it might fall apart at any moment. However, it should be good for a few more runs. The objective is the same as the past seasons; just put together the monkey to move on.
7. The Lightning Room: Same as it was in Season 2, though with the removal of the elevator, the objective has to be completed to move on.
8. The Chamber of Dry Waters: This room is a far cry from its predecessors, in that there's an objective you have to complete if you enter from Room 9. There are three chains, each on a different wall. In order to open the doors, the player has to yank on the correct chain, which will release a waterfall from an opening on the left wall. If entering from the Lightning Room, though, all you have to do is bust down the stone wall. The room itself is colored similarly to the Well from Season 1, though dark blue patches can be seen on the wall.
9. The Dark Forest: Same as before, though the arms of the trees are longer and more brittle.
10. The Murky Swamp: Same as "The Treacherous Swamp" back in Season 2, though with more vines hanging from the walls and on the ground, which can trip players up. The back wall is colored a dark green, while the foam pellets used are a mix of dark and forest green, probably to resemble the water.
11. The Lair of the Butterfly: This room has the same lighting as the Tomb of the Headless Kings, aside from two lights hanging on the back wall, separated by the Temple Guard door. Below those lights are open display cases, each with three large butterflies in them. A third display case is in the front of the room, presumably for an artifact that may be housed there. A butterfly statue, whose design is based on the Owl Butterfly, is placed on an outcropping that covers part of the ladder leading to the Heart Room. The player must grab the butterflies and rip their wings off. When they finish, they can move on; the butterfly statue will ominously glow blue to signify the completion of the room's objective.
12. The Moss Cavern: Pretty much the same as the Ledges, but moss has been growing throughout, hence the name change.
Layout 2
1. The Crypt
2. The Overgrown Pit/Rickety Bridge: A bridge has been added in order to gain access to the Eclipsed Light Room; the entrance to the Heart Room is blocked by a pole. These poles have been planted on the outcroppings, making the choice to go through the top or bottom paths essential. Down in the pit, the vines seem to be getting worse, as they're now emerging from the holes on the wall.
5. The Tomb of the Pharaoh: The room is decorated like an Egyptian tomb. In the center of the room is a sarcophagus, and scattered about are three items (two staffs and a decoration for the headdress) needed for it. The player must gather them and place them on the sarcophagus, but be careful! A Temple Guard may emerge from the sarcophagus.
6. Shrine of the Silver Monkey: The monkey has been rebuilt, and now looks like its former self again.
7. The Room of the Ancestral Mask: Three mannequin heads are sitting on platforms across the room, and in front of them is a mask. The player has to place it on the correct head in order to move on. This room retains the dark coloration its previous room had.
9. The Dark Forest
10. The Murky Swamp
12. The Moss Cavern
Layout 3
1. The Crypt
2. The Pit of Despair/Rickety Bridge: The vines have finally been cut away, and the Pit is back to its former self, with the exception of the marks on the wall made by whatever was used to cut the vines away. Although the Pit uses the same blocks as the Pit and the Pendulum, the pendulum itself has been removed. The bridge is still standing.
3. The Eclipsed Light Room (V2): The objective has been changed a bit. Instead of one black orb and three panels, this room has three black orbs and one panel. The orbs can be moved around, and one of them contains a light within. To reveal this light, the orb must be turned until it is exposed via a hole on the black cover.
8. The Chamber of Dry Mists: The waterfall has disappeared, and in its place is a clear mist. Like in the Chamber of Dry Waters, players have to pull on the right chain to release the mists. If they came here from the Room of the Ancestral Mask, all they have to do is bust through the wall. The room's colors are a bit darker than they were before.
9. The Dark Forest
10. The Crystalline Lake: In place of the vines are large crystals that obstruct the player's path. They must maneuver through them in order to reach the next room. The pellets are a light blue, and the wall is a mix of blue and green.
12. The Moss Cavern
Layout 4
1. The Crypt
2. The Pit of Despair: The bridge has been removed, though most of the outcroppings remain; the central one was destroyed along with the bridge. A rope has been added to help players get across.
3. The Prisoner's Tower: In the front of the room are three jars, and in the back is a cage with 'someone' (actually a dummy) stored inside. The player has to open the jars and find a key to release the prisoner in order to move on. The night sky appearance that the Eclipsed Light Room had has been replaced with dark gray, as if to resemble a prison.
4. The Room of Eternal Melody: Three instruments (a flute, a clarinet, and a trumpet) are strewn across the room, and in the front are a pair of hands. The player must place the correct instrument on the hands to move on; to signify this, music will begin to play (usually the first three notes of the Temple Run music). The room is a mix of gray and white.
9. The Dark Forest
11. The Abyssal Ruin: In this room are four chests, with a fifth one sitting in a skeleton's lap on a chair by the ladder. The player has to go through the four chests until he finds a key, which will open the one with the skeleton. The room has dark blue lighting to make it resemble the ocean depths, and it's been said that the previous room, the Lair of the Butterfly, somehow created this room.
12. The Moss Cavern
Layout 5
1. The Crypt
5. The Hall of Memories: In the front of the room is a basket with the player's team insignia on it, and behind them are three artifacts, of which one of them was once sought after by their team. These artifacts are ones that were never retrieved from the Temple; artifacts that were at least grabbed before time ran out are exempt from this. The player must put the correct artifact in the basket to move on. The room has a light brown background, with two green doors for the Temple Guards to come out of, making it look similar to a room that came out of Season 1.
7. The Room of the Secret Password: Same as before.
9. The Dark Forest
12. The Moss Cavern
Layout 6
1. The Crypt
7. The Artist's Studio: Scattered about the walls of the room are paintings made by various artists, and a canvas in the front. Players have to place the correct painting on the canvas in order to move on. The room is splashed with various colors of paint, and a few sheets of paper are on the walls and the floor.
9. The Graverobber's Haunt: In this room are three coffins, each containing a skeleton. One of these skeletons is holding a key to the next room. Be careful, though! One of these coffins may contain an angry Temple Guard who will think you're the graverobber. Give him a Pendant to keep him at bay, or 'take his place in the coffin', as Kirk would call it. The room is decorated with piles of dirt, a tombstone by the coffin lying on the ground, and a bag filled with valuables.
12. The Moss Cavern
And now, for the episodes. I checked as much as I could to make sure I didn't duplicate anyone's, but there's a likely chance I missed someplace where I could have looked. I really hope I didn't steal anyone's artifact, but if I did, please let me know right away.
Layout 1
Episode 1: The Model Manuscript of Copernicus
Episode 2: The Jolly Roger of Emanuel Wynn
Episode 3: The Paper Crown of the Duke of York
Episode 4: The Old Plank of the Theatre
Episode 5: The Golden Apple of Eris
Episode 6: The Controversial Painting of Diego Rivera
Episode 7: The Pierced Helmet of Richard III
Layout 2
Episode 8: The Pomegranate Seeds of Persephone
Episode 9: The Lost Diamond of Orapa
Episode 10: The Missing Triptych of Hieronymus Bosch
Episode 11: The Torn Sail of the HMS Resolution
Episode 12: The Burnt Feather of Olga of Kiev
Episode 13: The Discarded Pith Helmet of Reginald Wingate
Layout 3
Episode 14: The Ivory Tusk of W.D.M. Bell
Episode 15: The Broken Staff of Itzcoatl
Episode 16: The Destroyed Stone Wall of Harfleur
Episode 17: The Broken Sword of Imagawa Yoshimoto
Episode 18: The Black Robe of Vlad the Impaler
Episode 19: The Royal Headdress of Ramses I
Episode 20: The Gold Medal of Jackie Joyner
Episode 21: The Lost Pages of Edgar Allan Poe
Layout 4
Episode 22: The Broken Ramrod of Molly Pitcher
Episode 23: The Unfinished Painting of Georges Seurat
Episode 24: The Smithing Hammer of Hephaestus
Episode 25: The Ruined Crown of the Corrupt Emperor (Li of Zhou)
Episode 26: The Crystal Ball of John Dee
Episode 27: The Hair Boat of Marie Antoinette
Layout 5
Episode 28: The Lance Fragment of Gabriel Montgomery (used w/permission from The Bandit King)
Episode 29: The Lost Diary of Rudolf Diesel
Episode 30: The Missing Recipe of Ruth Wakefield
Episode 31: The Golden Hair of Sif
Episode 32: The Calculating Tables of John Napier
Episode 33: The Fractured Axe Handle of Big Joe Mufferaw
Episode 34: The Ancient Glyph of K'an II
Layout 6
Episode 35: The Final Letter of Percy Fawcett
Episode 36: The Siege of Constantinople and the Greek Fire Tube
Episode 37: The Long Coat of Doc Holliday
Episode 38: The Top Hat of Moshoeshoe I
Episode 39: The Distinguished Medal of Audie Murphy
Episode 40: The Unscathed Lyre of Emperor Nero
Trivia:
 - The Temple, at first, has a theme of decay to it, in order to imply that it hasn't been used in quite some time.
 - The year has been set! This will take place in 2002, and the prizes will reflect that time frame.
 - The episodes above were not in that order when I wrote them down. What I did was, soon after I finished, put them in a Random Sequence Generator. The result is the episode list you see above; for example, the Unscathed Lyre of Emperor Nero was number 16 on my list, but it wound up being the last episode of Season 1!
 - In addition, some of the artifacts didn't make the final cut. For example, one of the artifacts was "The Razor Blade of Vincent van Gogh", but I became concerned about it due to its dark nature, so it was swapped out for "The Unfinished Painting of Georges Seurat". As much as I want to do something on Vincent van Gogh, the razor blade he held towards his friend might be pushing it a bit. Though considering how dark Legends could get, maybe the artifact would fit in with it, so there's a possibility of it popping up in Season 2.
 - Some of these artifacts were...interesting to find out about. To me, the most outrageous of these would probably be Marie Antoinette's hair boat.
 - The beta title of this was Legends of the Hidden Temple: Echoes. This was scrapped because while the title sounded cool, it was also a bit silly. And I'm pretty sure I was thinking of Metroid Prime 2: Echoes when I thought of this. >_>
 - The Lair of the Butterfly (and, by extension, the Abyssal Ruin) was meant to be a reference to the 'butterfly effect' theory.
And that's about it! If all goes well, the first episode should be up next Thursday, hopefully not early in the morning when I should be asleep. I'll be updating this quite a bit, so be sure to check back often!
« Last Edit: August 25, 2013, 07:28:57 PM by NekoSuave »
Favorite Episode(s): The Much-Heralded Helmet of Sir Gawain, the Milk Bucket of Freydis, the Discarded Seal of Ivan the Terrible
Favorite Team: Purple Parrots
Favorite Room(s): The Dark Forest, followed by the Lightning Room and the Shrine of the Silver Monkey
What if Legends was brought back in 2002? You get Legends of the Hidden Temple: Unearthed (updates every one to two weeks, on Wednesdays)
Offline NekoSuave
  • Orange Iguana
  • Gender: Female
    • View Profile
Re: Legends of the Hidden Temple: Unearthed
« Reply #1 on: June 21, 2013, 02:33:56 PM »
Update:
 - Changed 'The Heliocentric Model of Copernicus' to 'The Model Manuscript of Copernicus'
 - Swapped out 'The Spare Herb of Odysseus' for 'The Old Plank of the Theatre'
 - Added/changed details about the rooms
 - Layout 6: 'The Room of the Ancestral Mask' has been swapped out for 'The Artist's Studio'
 - Trivia regarding the Lair of the Butterfly added
Offline The Bandit King
  • Recognized Legends God
  • Gender: Male
  • Okay, I finally have a tagline. Happy now?
    • View Profile
« Reply #2 on: June 21, 2013, 10:19:40 PM »
The amount of work you've put into this so far is impressive. I look forward to reading the first episode!
Favorite Episode: The Secret Map of the Bandit Queen
Favorite Room: The Chamber of the Sacred Markers
Favorite Team: Blue Barracudas
It's baaaaaaaack...
Legends of the Hidden Temple: Rebirth! (return date TBD)
1980s - Michael Jackson, Madonna, Bruce Springsteen, etc.
1990s - Mariah Carey, Boyz II Men, Nirvana, etc.
Present - Lady Gaga, Miley Cyrus, Justin Bieber, etc.
You do the math.
"Just when they think they've got the answers, I change the questions!"
--"Rowdy" Roddy Piper
Offline The Silver Monkey
  • Temple God
  • Olmec
  • Gender: Male
  • It's three pieces, it shouldn't be this hard!
    • View Profile
« Reply #3 on: June 21, 2013, 10:21:08 PM »
What he said. :grin:
Great to have another fanfic series to look forward to!
If you have seen all 120 episodes of Legends, copy and paste this into your signature for all to see.
Offline Purple Parrots Fan
  • Temple Spirit
  • Gender: Female
    • View Profile
« Reply #4 on: June 21, 2013, 10:30:16 PM »
Agreed. Especially the fanfic section has been dead in the Legends fandom for months.
And I love your idea of The Heart Room. :lol:
Offline NekoSuave
  • Orange Iguana
  • Gender: Female
    • View Profile
« Reply #5 on: August 04, 2013, 06:06:09 PM »
Okay, episode 3 should be coming up either tonight or tomorrow. Also, small update: the Hall of Memories room has received a makeover. Originally, it was supposed to look like the Room of the Ancient Warriors, but this was nixed because the Temple Guard encounters would look awkward. Instead, I decided to go for something that looked like it came out of Season 1, since this room's got to do with the show's past.
