Author Topic: Legends of the Hidden Temple: Rebirth-Layouts & Episo...  (Read 14538 times)
Offline The Bandit King
  • Recognized Legends God
  • Gender: Male
  • Okay, I finally have a tagline. Happy now?
    • View Profile
« on: July 24, 2009, 12:17:02 PM »
As you may have seen from some of my previous posts, I have been planning on posting some of my own fanfics.  Before I do that, however, I feel it’s common courtesy to give you the Temple Layouts and the fanfic titles I plan to use.
A few notes about the show: This show is a theoretical "rejuvenation" of Legends, which takes place in the present (as in right now, 2009-2010). Therefore, the prizes and allusions in the fanfics will reflect this. There will also be a few more changes that will be introduced as I go along.
The Temple Layouts
Each number corresponds with the number on the map.
Season 1
Season 1 has five Temple Layouts.
Layout 1
1. The Crypt--Same thing as the old show.
2. The Ledges--Same as always.
3. The Rope Labyrinth--This room is a large pit with numerous actuators leading to every room it borders.  Strewn around the room are several thick, white ropes that obstruct the contestant’s pathway to the other side.  The top half of the room contains more ropes than the bottom half, so no matter if a contestant enters the Temple via the Crypt or the Ledges, they will still have to crawl through some sort of obstacle to proceed.
4. The Great Seal Room--This room has a cylindrical column in the center, and at the back, a free-standing shelf with four distinct round seals on it.  The contestant must place the correct seal in a small indentation at the top of the column to open the door to the next room.
5. The Chamber of the Sacred Markers--Same as Season 3 of the old show.
6. The Tomb of the Headless Kings--This “veteran room” sees a major change this time around.  There are still two kings, but only one vine which opens the trapdoors, significantly reducing the amount of time needed to progress through the room.
7. The Safari Room--This room’s walls are decorated in animal-print, and five (fake) heads of African animals are mounted on the walls—two on either side of the room, and three in the back.  Going from left to right, the heads are those of a leopard, a rhinoceros, an elephant, a Cape buffalo, and a lion.  The contestant must push in the correct animal head to open the door to the next room.
8. The Bamboo Forest--Same as the Season 1 Bamboo Forest in the old show (here’s looking at you, TBF!).
9. The Shrine of the Silver Monkey--Could you really have Legends without this room?
10. The Dark Forest--Essentially the same, except the trees’ arms are quite a bit longer. The golden doors in the back lead to Room 11, Room 9, and Room 7, respectively.
11. The Room of the Secret Password--Same room, except the password “Klaatu barata nikto” has been replaced with “Dr. Livingstone, I presume”.
12. The Dungeon--Exactly the same room as Season 1 of the old Legends.
13. The Pharaoh’s Secret Passage--Same old, same old.
Layout 2
1. The Crypt
2. The Ledges
3. The Bottomless Pit--This room is essentially identical to The Pit from Season 2 of the old Legends.  A large room, filled with numerous plastic balls on the bottom, with two stone outcroppings on either side (the only difference is that the balls are colored black and purple).  The contestant must swing across on a rope hanging in the room and hit the actuator to open the door to the next room.
4. The Lookout Tower--This room contains nothing but a small telescope on the railing, looking out at the wall behind the audience, where a message is written.  However, the telescope is out of focus.  The contestant must use the two knobs on the left and right side of the telescope to focus it.  As soon as they can discern the message, they must yell out what it says to open the door to the next room.
5. The Geographer’s Study--This room is decorated with two old-fashioned globes on either side of it, but its most distinguishing characteristic is a large map of the world at the back (separated, of course, by the ladder into the Lookout Tower).  This map is missing several pieces, which are strewn about the room.  The contestant must find these pieces and correctly place them to open the door to the next room.
6. The Owl’s Nest--Six nests are arranged in a circle in the center of this room, and strewn all over the room are numerous stuffed owls.  The contestant must find the sole white owl among the other brown or gray ones, and then attach it to the one nest out of the six that it belongs on to open the door to the next room.
7. The Inventor’s Workshop--This room has a large capstan in the center of it, and a large “machine” with numerous gears dons the back wall.  The contestant must spin the capstan completely around four times, until the gears begin to turn (actually, the lighting in the room only gives the impression that they turn), and the door to the next room opens.
8. The Chamber of the Four Elements--Decorated like a Roman temple, this room has a large rectangle in the back separated into four parts.  Around the edges of the rectangle are four large tiles that fit into these slots.  These tiles are decorated with symbols of the four ancient Roman elements—fire, air, earth, and water.  The contestant must place the four tiles in the rectangle, in the correct order, to open the door to the next room.  In this Temple Layout, he tiles have no set order, so ANY combination could be the correct one, making this a very time-consuming room.  The room also has two ladders at the back, which lead to the Shrine of the Silver Monkey and the Inventor’s Workshop.
10. The Dark Forest
12. The Dungeon
Layout 3
1. The Crypt
2. The Ledges
4. The Lunar Landing--This room is decorated like the 1969 moon landing.  At the back of the room is a rotating cylinder decorated like a satellite.  Similar to the Season 1 Observatory, the contestant must align a puzzle on the satellite to open the door to the next room.
5. The Clockwork Room--This room has six clocks on the back wall (separated of course, by the Temple Guard door), with a seventh clock on the Temple Guard door itself.  The contestant must set the six clocks to the same time as the seventh clock (usually 12:00, but sometimes 6:00) to open the door to the next room.
6. The Atlantean Altar--Decorated up like sunken ruins, this room has eight tiles on the back wall (four on each side, similar to the Laser Light Room).  The contestant needs to uncover the tile that has blue light behind it to open the door to the next room.  Olmec calls this “uncovering the tile that lets in the waters of Atlantis”.
7. The Room of the Mystical Keys (used with permission from silverMarker)--There are 9 small compartments aligned in the back of the room (3x3).  The contestant must reach into the compartments and find two keys that are hidden in one each, and then place each one in the correct two of three respective pedestals to open the door.
8. The Jungle Ruins--This room is decorated like an ancient city in the rain forest, with stone structures, rocks and plants galore all over the room.  Like the Swamp from Season 2 of the old Legends, the contestant must maneuver around all this to get to the other side of the room to hit an actuator to go to the next room.
10. The Dark Forest
12. The Dungeon
Layout 4
1. The Crypt
2. The Ledges
4. The Sculptor's Studio--This room has three pedestals with a statue on top of each one.  Like the King’s Storeroom, the contestant must break open the hollow sculptures to find a key, which they then insert in the correct hole on the pedestals to open the door to the next room.
6. The Owl’s Nest
8. The Ancient Cave--This room, which is decorated like a cave, has a series of “cave paintings” depicting “cavemen” on the back wall.  Just like the Jester’s Court from Season 3 of the old Legends, the contestant must align their body with the correct wall painting to open the door to the next room.  The room also contains two ladders at the back, which lead to the Shrine of the Silver Monkey and the Inventor’s Workshop.
10. The Dark Forest
12. The Dungeon
Layout 5
1. The Crypt
2. The Ledges
4. The Magician’s Chamber--There are three pedestals in this room, each with a top hat on it.  The contestant must wave their hand over the top hats to find the (stuffed) rabbit, which will jump out when the hat that contains it is waved over.  The rabbit must then be pulled out of the hat to open the door to the next room.
7. The Room of the Golden Torches (used with permission from The Bamboo Forest)--There are three golden torches in the three pedestals of the room, and each has a large bulb on top. The contestant must take a long stick with a "flame" on its tip (just another bulb like the ones on the torches) and touch the tips of the three torches gently. When the correct one lights up, the doors open.
8. The Snake Pit--This room is identical to the Jungle Ruins, except that most of the plants and stone structures are gone, and numerous rubber snakes litter the room—seven, to be exact.  The contestant must place all seven snakes in a large tree stump at the back of the room to open the door to the next room.
10. The Dark Forest
12. The Dungeon
Season 2
Season 2 only has three Temple layouts.
Layout 1
1. The Crypt
2. The Ledges
5. The Candelabra Room--Located on the back wall of this room are six candelabras—three to the right of the door to the Great Seal Room, and three to the left of it.  The contestant must push the actuator under the correct candelabra to light it up, which will open the door to the next room.
7. The Safari Room
8. The Snake Pit--Same room, new objective. The snakes are now made of cloth bags stuffed with pellets, like a beanbag, and they're much larger, about the size of a door draft-guard. The contestant must find all the snakes in the room (either two or three, depending on the episode) and thread them through a large hole in the side of the tree stump to open the door to the next room.
10. The Dark Forest
11. The Lightning Ball Room--Exactly the same as the old Lightning Ball Room.
12. The Dungeon
Layout 2
1. The Crypt
2. The Ledges
6. The Jewel Mine--In the center of this room is a stationary mine cart. Scattered about the room are ten jewels. The contestant must place all the jewels in the mine cart to open the door to the next room. A Temple Guard may also be hiding in the mine cart.
7. The Shaolin Dojo--Sort of like the Room of the Ancient Warriors, except I’ve added my own twist to it.  A yin-yang symbol at the front of the room, and at the back are three suits of armor.  The player must place the yin-yang on the chest of the correct suit of armor to open the door to the next room.  One of the suits of armor could be possessed by a Temple Guard.
8. The Chamber of the Four Elements--Same name, same objective, one big difference--above the slots where the element tiles should go, a pattern above them indicates the correct tile for the slot.  This greatly reduces the amount of time that must be spent in the room.
10. The Dark Forest
12. The Dungeon
Layout 3
1. The Crypt
2. The Ledges
5. The Room of the Mystical Keys
7. The Safari Room
8. The Ancient Cave
10. The Dark Forest
12. The Dungeon
Tournament of Champions Layout
1. The Crypt
2. The Ledges
6. The Tomb of Forgotten Treasures--This room consists of eight compartments at the back of the room, each one filled with an artifact from a previous episode.  The player must find the artifact from the episode they first appeared on and place it on a pedestal in order to proceed.
7. The Emperor’s Storeroom--This new room is a nod to the King’s Storeroom from episodes past.  Decorated like a Chinese temple, it features six pedestals near the back of the room, with enough space between them and the back wall for the player to walk between.  Each pedestal has a ceramic pot decorated like a priceless Ming vase.  The player must smash the vases in search of a key, then insert said key into the right hole in one of the pedestals to open the door to the next room.
8. The Ancient Cave
10. The Dark Forest
11. The Tortoise’s Territory--A long, narrow post stands in the center of the room, and six turtle shells are arranged in a row at the back.  The player must stack the turtle shells on the post, in order from smallest to largest, to open the door to the next room.  Only the smallest shell will go on the bottom, only the next-to-smallest shell will go on top of the smallest shell, etc.
12. The Dungeon
And now, the episodes themselves.  Hope I didn’t duplicate (or come close to duplicating) anybody’s.  If I did, I profoundly and deeply apologize.
Season 1
Layout 1
Episode 1: The Infamous Lion Skin of the Tsavo Hunter
Episode 2: The Golden Amulet of Cuauhtémoc
Episode 3: The Silk Cummerbund of Elvis Presley (used with permission from the 49th Ronin)
Episode 4: The 12-Starred Flag of Betsy Ross
Episode 5: The Broad-Brimmed Fedora of Robert Ripley (used with permission from the 49th Ronin)
Episode 6: The Well-Worn Gloves of Joe Louis
Episode 7: The Silver Spurs of Buffalo Bill
Episode 8: The Lost Cap of Casey Jones
Episode 9: The Burnt French Flag of Louis the Thirteenth
Episode 10: The Rudder from the HMS Endurance
Episode 11: The Tortoiseshell Comb of Eleanor of Aquitaine
Episode 12: The Orbit Maps of Johannes Kepler
Episode 13: The Original Spelling Book of Noah Webster
Episode 14: The Lost Blueprints of Charles Babbage
Layout 2
Episode 15: The Broken Helmet of Erik the Red
Episode 16: The Bamboo Katana of Kamiizumi Nobutsuna
Episode 17: The Feathered Crown of Nezahualcoyotl
Episode 18: The Battered Helmet of Henry the Second
Episode 19: The Discarded Sweatband of Jesse Owens
Episode 20: The Wedding Ring of Nocatula
Layout 3
Episode 21: The Inaccurate Map of Gerardus Mercator
Episode 22: The Leather Scabbard of William Wallace
Episode 23: The Missing Letter of Amerigo Vespucci
Episode 24: The Stone Nose of the Easter Island Statue
Episode 25: The Petrified Sandal of Pygmalion
Episode 26: The Jeweled Crown of Esther
Episode 27: The Golden Rose of King Midas (used with permission from The Ancient Warrior)
Layout 4
Episode 28: Beowulf’s Shattered Sword
Episode 29: The Lost Pages of the Yì J?n J?ng
Episode 30: The Scorched Cake Pan of Alfred the Great
Episode 31: The Surviving Blueprints of Edward Teller
Episode 32: The Torn Journal Page of Admiral Byrd
Episode 33: The Smashed Statue of Darius the Second
Episode 34: The Crumpled Ballot of Susan B. Anthony
Layout 5
Episode 35: The Modified Charts of Pedro Álvares Cabral
Episode 36: The Model Heart of William Harvey
Episode 37: The Torn Veil of Angela Merici
Episode 38: The Monogrammed Printing Plate of Johann Gutenberg
Episode 39: Qui Shih Huang Ti and the Elixir of Life
Episode 40: The Lost Knife Sheath of Jim Bowie
Season 2
Layout 1
Episode 41: The Secret Code of the Condemned Pirate
Episode 42: The Broken Harpoon of Thor Heyerdahl
Episode 43: The Oxygen-Filled Bell Jar of Joseph Priestley
Episode 44: The Condor-Feathered Hat of John Muir
Episode 45: The Tattered Banner of Mother Lu
Episode 46: The Well-Weathered Pirate's Flag of Ned Lowe
Episode 47: The Bearskin Cloak of Jim Bridger
Episode 48: The Mystical Earring of Tenskwatawa
Episode 49: Democritus’ Half-Eaten Gyro
Episode 50: The Oil-Soaked Rags of the Japanese Ninja
Episode 51: The Misfired Rocket of Wan Hu
Episode 52: The Marble Shard of the Mausoleum
Episode 53: The Unused Chains of Red Legs Greaves
Layout 2
Episode 54: The Discarded Dentures of John Greenwood
Episode 55: The Stolen Tarnkappe of Siegfried
Episode 56: The Wooden Figurehead of the Viking Ship
Episode 57: The Rose-Adorned Hairpin of Laura Bullion
Episode 58: The Eagle Feather Headdress of the Zulu Chieftain
Episode 59: The Mysterious Material of the Roswell Object (used with permission from DrThinker)
Episode 60: The Ruby Pendant of Princess Caraboo
Episode 61: Kaguyahime’s Mystical Robe (used with permission from DrThinker)
Episode 62: The Golden Apple from the Edge of the World
Episode 63: The Satin Evening Gown of Emily Dickinson
Episode 64: The Paint-Stained Tablecloth of Claude Monet
Episode 65: The Letter-Embroidered Cloth of Nathaniel Hawthorne
Episode 66: The Bullet-Pierced Playing Card of Charles Cognetz
Layout 3
The Abandoned Hut Door of Alexander Selkirk
The Bullet-Grazed Burnoose of the Warrior Sheik
The Cracked Shield of Scipio Africanus
The Ebony Abacus of the Indian Mathematician
The Fossilized Tooth of Richard Owen
The Heart-Shaped Urn of Damon and Pythias
The Kachina Staff of Pope Pueblo
The Metal Body Armor of Ned Kelly
The Red Flag of Christopher Moody
The Right Arm of the Venus de Milo
The Soil-Stained Hiking Boots of Hiram Bingham
The Sun-Adorned Crown of the Egyptian Pharaoh
The Very Valuable Soap Cake of Jefferson Smith
The Warning Letter from Albert Einstein
Tournament of Champions Episodes
Episode 81: The Bronze Helmet of the Spartan General (semi-final)
Episode 82: The Mummified Paw of the Egyptian Cat (semi-final)
Episode 83: The Golden Bracelet of Niobe (semi-final)
Episode 84: The Dragon-Tooth Necklace of Medea (semi-final)
Episode 85: The Snapped Sword of Tobari (finale)
Interviews
*Ashleigh Morrows talks about her experience as a Silver Snake in the pilot episode, "The Infamous Lion Skin of the Tsavo Hunter".
*Tyson Schultz discusses his time on the show, and why he grabbed an artifact when time expired in "The Missing Letter of Amerigo Vespucci".
There you go. I'll be updating this often, so check back whenever you can.
Temple artwork in some episodes provided by JTH1.
« Last Edit: November 05, 2011, 12:11:45 AM by The Bandit King »
Favorite Episode: The Secret Map of the Bandit Queen
Favorite Room: The Chamber of the Sacred Markers
Favorite Team: Blue Barracudas
It's baaaaaaaack...
Legends of the Hidden Temple: Rebirth! (return date TBD)
1980s - Michael Jackson, Madonna, Bruce Springsteen, etc.
1990s - Mariah Carey, Boyz II Men, Nirvana, etc.
Present - Lady Gaga, Miley Cyrus, Justin Bieber, etc.
You do the math.
"Just when they think they've got the answers, I change the questions!"
--"Rowdy" Roddy Piper
Offline The Silver Monkey
  • Temple God
  • Olmec
  • Gender: Male
  • It's three pieces, it shouldn't be this hard!
    • View Profile
Re: Legends of the Hidden Temple--The New Show Layouts
« Reply #1 on: July 24, 2009, 12:36:48 PM »
Quote from: ""The Bandit King""
BTW, does anyone know how to put pictures in posts? I still haven't figured it out... :oops:
[*img]URL of image here[/img*] (Remove the asterisks)
If you have seen all 120 episodes of Legends, copy and paste this into your signature for all to see.
  • Gender: Male
    • View Profile
« Reply #2 on: August 03, 2009, 05:29:14 PM »
UPDATE:
I've uploaded a few more episodes, and changed the name of my future fanfic of "The Bullet-Shot Playing Card of Charles Cognetz" to "The Bullet-Pierced Playing Card of Charles Cognetz.
In addition, I've decided to nix "The Brass Astrolabe of Nicolas de Ovando" in favor of another episode. Any ideas for replacements would be appreciated.
It's baaaaaaaack...
You do the math.
Offline The Ancient Warrior
  • Temple Spirit
  • Gender: Male
  • Peace, joy and omelettes!
    • View Profile
    • http://www.freewebs.com/ancientwarrior07/index.htm
« Reply #3 on: August 03, 2009, 05:36:39 PM »
Are you looking for a new subject, new artifact or both?
If you have seen all 120 full episodes of Legends, copy and paste this into your profile for all to see.
The Room of the Ancient Warriors | Legends: The Rediscovery (Season 3 resumption date TBD)
Favorite episode: The Levitating Dog Leash of Nostradamus
Favorite season: Season 2, very closely followed by Season 3
Favorite team: Blue Barracudas
Credit to Nicklegends for the screencap in the avatar and for Mr. Blue.  Thanks dude!
  • Gender: Male
    • View Profile
« Reply #4 on: August 03, 2009, 05:44:41 PM »
New artifact.
It's baaaaaaaack...
You do the math.
  • Gender: Male
    • View Profile
« Reply #5 on: August 04, 2009, 05:54:59 PM »
UPDATE:
I've changed "The Brass Astrolabe of Nicolas de Ovando" to "The Modified Charts of Pedro Alvares Cabral. Also, I only recently realized that TAW has done a legend about Akhenaton, so I've changed "The Smashed Statue of Akhenaton" to "The Smashed Statue of Darius the Second".
I've also added a new room to one of my layouts--The Clockwork Room.
It's baaaaaaaack...
You do the math.
Offline The Bamboo Forest
  • Gender: Male
    • View Profile
    • The Bamboo Forest
« Reply #6 on: August 04, 2009, 06:53:17 PM »
So, is Season 1 production order and Season 2 alphabetical/airing order? Or is there a different system for you sorting episodes?
Favorite Season: Season Two
Favorite Episode: The Lucky Pillow of Annie Taylor
Favorite Team: Orange Iguanas
Favorite Room: The Bamboo Forest
Seen all 120 episodes of Legends.
Justin Bieber and Lady Gaga: The Epitomes of Musical Fart
Fanfiction Projects (On hold): Legends: Wild Jungle
  • Gender: Male
    • View Profile
« Reply #7 on: August 05, 2009, 07:52:51 PM »
Yeah. Thing was, I was just too lazy to sort the Season 2 Episodes, so I just put 'em in alphabetical order for right now. I might order them differently later if I feel like it.
It's baaaaaaaack...
You do the math.
  • Gender: Male
    • View Profile
« Reply #8 on: August 12, 2009, 01:21:16 PM »
UPDATE:
Episode 10 is now up.
Also, since my college classes start tomorrow, production of these things is going to become quite a bit slower (as in one episode every 2 or 3 weeks  :cry: ). Please understand.
It's baaaaaaaack...
You do the math.
Offline lothtfan
  • Purple Parrot
    • View Profile
« Reply #9 on: August 14, 2009, 10:50:05 AM »
WHAT???????!!! That was gonna be my project!! :(
  • Temple Spirit
  • Gender: Male
    • View Profile
« Reply #10 on: August 14, 2009, 12:20:16 PM »
Well, looks like he beat you to actually writing stuff.  I think it'd be way easier for you to just change the title than it would be for him, seeing as you haven't even posted one episode. ^^;
  • Gender: Male
    • View Profile
    • The Bamboo Forest
« Reply #11 on: August 14, 2009, 03:17:01 PM »
True dat. You should both have the reason to be a little disappointed, but he did make the effort to get some stuff organized and up here. :?
  • Gender: Male
    • View Profile
« Reply #12 on: August 14, 2009, 03:26:21 PM »
Quote from: ""lothtfan""
Sorry...I actually saw your post, and was waiting for you to post something before I actually started this thing. Since you didn't post anything for several days, I went ahead and did it. If you really want, I can change my project name, instead of you changing yours (since you did come up with it first...)
It's baaaaaaaack...
You do the math.
  • Gender: Male
    • View Profile
« Reply #13 on: August 15, 2009, 12:37:26 PM »
UPDATE:
Since lothtfan didn't respond to my invitation to let him use Rebirth for his project name the last time he was on here, my project name will remain the same.
Episode 11 should be up sometime tonight or tomorrow. Keep an eye out for it.
It's baaaaaaaack...
You do the math.
Offline lothtfan
  • Purple Parrot
    • View Profile
« Reply #14 on: August 16, 2009, 08:13:53 AM »
I'll just do Season 4 Fanfiction.
