TEMPLE RUN:
FOG: The Purple Parrots?Chris and Tina had earned the right to enter Olmec?s temple?but before we began?Olmec will tell you about his temple?which might get you a clue to get the Witch?s Lair were the Mysterious Metal of the UFO metal is.
OLMEC: You could start out by crawling though the Ancient Sewer (1) or running into and ringing one of the three bells in The Bell Tower (12). If you lucky, you may enter the Mysterious Hallway of Stairs (2). You could head up into the Mirror Room. (3) Spin the mirror, which might open the path to the Witch Lair (4). Toss the two snakes into the pot and you may land in the Skeleton?s Room (5). Put the head and the two hands on the skeleton?and you may be heading the Shrine of the Golden Monkey (6). Put together the golden monkey and you may be entering the Temple Bank (7). Spin the right safe?s wheel and you may be entering the Room of Power (
. Connect the cords to the Power Orb and you may be entering the Room of the Four Moons (9). Push down on the right phrase of the Moon and you may be entering the Rain Forrest (10). Look for the keys to the door in the tree?but beware a Temple Spirit might be a tree. Get out of that room and you will be King?s Storeroom (11). Smash the clay pots to find the keys. Find the correct key that lead you back to the Mirror Room or Witch Lairs, jump across the stairs, either run across the Bell Tower or re-crawl though the Ancient Sewer back to the gates. The choices are you and you are alone. You had won one ?Pendent of Life? medals in the Temple Games. Who is going first?
TINA: I am!
OLMEC: Tina, when Kirk gets the signal, run into the temple, and makes path to that takes you to the UFO metal. They are three Temple Guards assigned to protect three rooms. If you meet up with them?you must give up a Pendent of Life. If you caught with out a pendent, it will be your partner?s turn in the temple. If you get the UFO?s metal, all the door will mysterious unlock?and the temple guards will vanish! If you bring out the gown out of the temple in 3 minutes, you will be handsomely reward?and these are prizes for doing it.
[For getting into the temple: A snowboard. For getting the object: A portable DVD player. For getting the Mysterious Metal of the Roswell UFO out of the temple: A Walt Disney vacation.)
Fog: Olmec, lower your gate. Let set the clock for 3 minutes. On your mark, get set and go!
(Tina rushes up to the Bell Room, and rings the closet ball to the Olmec open path to the Mysterious Hallway of Stairs at 2:50.)
(Tina runs over to the Witch/Stair door but it does not open. Chris yells, ?Take a long path!? at 2:45)
(Tina heads for the Mirror/Star door?it opens at 2:38.)
(Tina enters the Mirror Room at 2:31.)
(Tina hits the Mirror Room?s Mirror but the Mirror is not glass?but a plastic/wood/rubber combo. Kirk yells, ?Spin it, Tina!? at 2:20.)
(Tina does the spin the Mirror Room?s mirror at 2:21?which opens the path to the King?s Storeroom.)
(Tina enters the King?s Storeroom at 2:19. She starts smashing clay pots to find the key?and finds the correct key and the correct column at 1:55. Tina sighs as she looked over at the Witch/Storeroom?s closed door. Tina growls the following: ?I won?t be surprise if the next room contains a temple guard.? as heads for the Forrest/Storeroom door.)
(Tina enters the Rain Forrest at 1:45.)
(Tina starts with the tree on close to her. It is a TEMPLE SPIRIT! Tina takes a while to get the Pendent of Life off?but she gives it the Temple Spirit with 1:30 left on the clock.)
(Tina checks the other tree. That tree did not have the key the player needs to head downwards to the Temple Bank?she sees rushes and hit the button to open the Room of the Four Moons at 1:20.)
(Tina meets up with her second Temple Guard in the Room of The Four Moons at 1:19. Chris gets into the Temple at 1:15.)
(Chris gets to the Room of the Four Moons at 0:55. He starts spinning the Moons faces?and opens the Moons/Power Room at 0:45.)
(Chris arrives in the Power Room to meet the final TEMPLE GUARD at 0:30)
FOG: Take about bad luck day for you, Parrots. You run into the three temple guards?they can be unfair! This got to one of the most unfair runs in the history of this show!
TINYA: (The third Temple Guard) Very funny, Mr. Cloud?but I take my job as temple guardian serious. If they took the bottom path, they made have go avoid the guard in the Room of the Four Moons and me.
OLMEC: Kirk, I forget to mention that Tinya is A TEMPLE GUARD.
TINYA: I was teaching some new guardians the ropes. Oh, I was just hanging around?getting a hand of things?for my own game show for my own planet. The new guards can handle the duty as well as the old ones. See you later, Olmec. (Blows a kiss)
(An old fashion sci-fi beam?like the Transporter from the original Star Trek?beams Tinya out of the studio.)
KIRK: Well, see you again for another hunt for one of the ?Legends of the Hidden Temple?! Nevertheless, for right now-I had one word for you: Goodbye!
(Credits)
